RB26 roll call?
Scott Buwalda
Hey guys:
There's a few on this board that have the 26. Perhaps we can take roll and start an e-mail group or something? It would be nice to discuss together some of the pitfalls of this swap (particularly in the 240SX), parts suppliers, easy horsepower, etc.
I'll go first:
Scott BuwaldaCumming (Atlanta area), GAR32 RB26DETTS14
Thanx in advance,
Scott
Phat_Optimo
Car: 93 S13 SE
Jason S Memphis TNR32 Rb26 don't know the year...Going into Z32Currently doing a tune-up to the motor and looking for a good chassis. We are looking at chopping the front diff housing off the 26 oil pan and using the GTR transmission in RWD mode only. I haven't thought too much about the wiring yet. Wonder how the ECU will react to missing sensors.... Might have to use a Power FC or something similar.
gani
Car: cars what else
got one too r32 rb26 in a s13 coupe still finishing up the swap with roll cage ,big brakes and all. so hopefully will be running by next month.
FAST-DATSUN
one S13 and 2 S14!!!!!!!!!!
Nameless EJ6
Car: What the **** do you think.
I'll be starting this summer. Everything is ready to drop in.. just need money for intercooler parts. mount kit, etc.
See sig
b-s14
hey scott, do you still remember how to do the wiring for rb26 to s14..? or did you send it out.. ?
Scott Buwalda
We are working through the wiring right now as we speak. We have both FSM's, and I have a phenom in S14 wiring helping me out (Russ Gogans). Plus it helps I have copper in my veins too. We'll make note of what goes where...but it's pretty straight forward...a few FSM's, some solder, a soldering iron, heat shrink, and a few hours to track everything down...
cyris3d
JustinVegasRB26-T04r76 Datsun 280z
b-s14
hey scott, you have pictures of your setup?
Scott Buwalda
Perhaps in a few weeks, but right now it just looks like an RB26 vomited in my shop. Parts everywhere. Good news is that the block is painted. Now I need to figure out how this damn JUN crank collar works. My ability to read Japanese directions is nill. Anyone have any idea? Is there machining involved, or is it a plug and play install? Oh well, if it turns out to be a pain, I'll see if I can source an R33 crank.
Scott
cyris3d
lemme know how that crank colar werks out.. whod ya order it from and how much?
Scott Buwalda
Looks like the crank collar needs to be machined. So my options are to find a local machine shop, or source an R33 crank.
I purchased it through RB Motoring. I think it was $180 or so...
Scott
underground
Car: 98 RB26DET 240SX
Chris Riggs- Underground MotorsportsLittle Rock, ARR33 RB26DETT/ Innovative Dual Ball-Bearing Turbo 98 S14
bankrup3000gt
s13 convertabler32 rb26dettrhdshould be finished in about a month.
Scott Buwalda
Wicked.
Alright. I have a question. I went to fit the RB25 oil pan today and the OEM RB26 oil strainer is in the way. What to do now...bend the strainer...modify it...?
Scott
Nameless EJ6
Scott Buwalda wrote:Wicked.
Scott
I'm using the RB25DET strainer.. but still had to cut it.
Either one needs cutting. Get someone who has a plasma cutter to quickly cut it away. It's cake.
gani
Car: cars what else
YOU HAVE TO cut the 20-25 oil pan rail to fit it on the 26 oil-pick up. Since the 20-25 oilpan is 1-1.5 inches more narrow then the 26's oil pan, the side of the oil pan has to be modified by haveing a semicircle added (l take a round pipe and cut it in half and trim it to fit.) to be able to fit the oil-pickup. Also there are plates at the back end of the 20-25 oil pan for baffling that need to be cut off. Well on the 26 oilpan/diif it does not come with those, but instead those plates are attached on the rb26 crank girdle, I ziz-wheeled the 20-25 oil-pan plates off, then hammered them down to be flush. Well, that was not enough, the 26 plates still hit the 20-25 oilpan, so thankfully the metal is malluable, and I banged on it for an hour with a hammer and dolly , making it clear. you still have to cut off some of the front baffles so that the oil pickup goes down the right way. after all that voila bolt that thing up.
just my 2 psi
underground
Guys, we all probably know about the Supra site, T04r.com.
I am fixing to begin working on skylinepowered.com, which will be very similiar, but list all the RB swapped cars making over xxx# of HP, yet to be determined..
Any of you guys interested? Think its a good idea?
jayz706
Jay Wilson94 s14 R32 rb26dettJust removed from clip
jayz706
here's the work in progress as of today...
jayz706
Thank you......
JCAP_Tuning
Scott scan the directions and email them to me, my gf reads Japanese.
BoostFab
Car: S13cp, S13fb, S14z
jayz706 wrote:here's the work in progress as of today...
nice, i can see some orange peel; maybe a good wet sanding will get rid of.
TheSnail
Car: RB26 powered 93 s13
I got a rb26 in mine here in GA aswell. Mine is in a s13.
tophatperformance
Car: Going fast
Maybe i can get me one soon!!!!!!
tophatperformance
Car: Going fast
You think you guys can help me out when i get one????
TheSnail
Hey, is that you Mike? If so, this is Voya.
See you tomarrow.
tophatperformance
Car: Going fast
Im really glad to be working with you guys on the RB26s and hope we can put out a great product. I need to get on these forums more i guess. Dont forget the 17th at Andretti speed lab and im hoping to see at least one RB26 with Top Hat mounts there.
OlyDriftSquad
Jst got my new toy at the house. rb26dett out of a 1996 r33, gtr going into my rhd s14, awd project.. hehe olny reason awd is cause i have the entire r33.. w/some side damage..
Scott Buwalda
Hey Mike:
Yeah man, I am stoked too. Sounds like TopHat will soon be having a good showing with RB26-powered S13's and S14's!
Scott
