RB26 rods in RB20
BoostFab
Car: S13cp, S13fb, S14z
do you guys think any advantage of using the rb26's oem rod in the rb20?
goofynick6
Car: 1995 S14.5 RB20DET
I believe it strokes it to a 2.1 or 2.2L
goofynick6
Maybe that's only with the rb26 crank?
DSMs_Suck
Car: Money, *****es, and 40s
Nick.. a rod has no possible way to increase the stroke in the motor... It can simply offset the piston TDC point up or down.The CRANK however will stroke the motor... and with a stock bore I believe it goes to about a 2.2
BoostsFed, from what I understand the rb26 rods are much thicker and forged so there would definately be a good reason to use them. However if you are using the rb20 crank I think they are going to be a little to short and you will end up with too much deck height. Basically what I am saying is check the rod length between the 2 rods... If its not the same then u cant use them.
BoostFab
yup, stroke only happen with the crank
goofynick6
Yeah my bad I was in a hurry yesterday and wasn't thinking.
Our stock units are already forged I believe, just the pistons that really suck. But if you have it apart and wanna upgrade why not right?
Nick
BoostFab
too bad the 26 crank doesn't come around easily.
i'm really debating on getting another rb20 long block....bore out to ~82mm & drop some forgies in there. or get a rb25det block and forged internals instead.
definately the latter will yield more power, since the 25 already got the torque grunt.
