And question came up, pertaining to RB26 and oil pan issue.
I was told that Rb25 oil pan wouldnt fit onto rb26.
As far as I knew bolt holes had to be opened up, and possibly block had to be drilled and tapped to fit RB25 pan onto Rb26.
I picked up a Rb25 pan for my 26 build but it never crossed my mind to test fit it and see whats the deal with it.
Block is sitting with head on it with bunch of stuff on it, dont feel like pulling that som'b**** out and flippin it over
Came across this thread rb25-oilpan-modification-t280195.html
So baffle has to be cut? What pick up tube is used with this? Why does the side of the pan look funny not straight, is that for turbo return?
I thought that if you use rb25 pick up tube with 25 pan its a bolt on.
Would appreciate some input from someone that did this first hand or is knowledgeable on this.
Thanks guys
Matt.
