I have an R33 GTS. I have installed an ATI balancer (made for a GTR) and ran into a problem with the power steering pump.
The balancer pulley is 4 grooves and the RB25 stock power steering pump pulley is 3 grooves and the belt was coming off at higher RPMs.
I found an R33 GTR power steering pump (because the pulley is 4 grooves) but it doesn't line up correctly. And it appears changing the stock pulley is an options, unless someone knows how to remove it???
Anyone else have any experience with this??? I have an R33 GTR pump bracket on the way, anyone know if it will it bolt up to the 25 block? Or if there is some other way to make it work?
