Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Tue May 03, 2011 7:58 pm
I would double-check your vacuum hoses and make sure that you do not have a vacuum leak. Just because you do not have a boost leak, does not mean that you don't have a vacuum leak. 5 in/Hg drop seems a lot to me. What degree/duration/lift did you go with????
However, It is normal for the vacuum level to drop a little with the installation of larger aftermarket cams. This is due to the larger duration that the cam allows the valve to stay open. So, the higher the duration, the lower the vacuum, and vice-versa.
