Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Mon May 04, 2009 11:34 am
How did you flush out the block? Did you pull the rear drain plug from the side?
Could be anything at with the information given... You could have a blocked radiator, a leaking hose, poor ducting, fans not working, poor to no coolant, waterpump issues, etc.
More info will bring people in to help you... plus there is a thread by title, "help my RB is overheating" or something that covers all the issues and solutions that could be going on.
As far as the head gasket, there are so many ways to check for this, common way is to check if your engine is mixing coolant and oil making it look like creamy chocolate milk (yoohoo).
