ReganECR33 »
https://forums.nicoclub.com/reganecr33-u215922.html
Wed Apr 03, 2013 5:19 pm
well their doing it for a reason bro, u want to be original do a 4g63rwd swap into an s13, they make more power then a 2jz and alot cheaper, ive had most almost all of the top jdm engines and the rb is by far the most expensive 1 to keep runing and to upgrade, dont know why i still have my skyline lol if i could take all the money back i spent on my rb's id buy a 2jz and put it into my skyline, their is also another option which for me was the most viable but i got lazy and just bought the tomei pump, u can run a single stage external oil pump and have it fed into your oil pump carcass a budy of mine in australia has his setup like that, basically you tap into your oil pan then get a line to your single stage oilpump,then take out the guts of your oil pump and run a line from the single stage oil pump to the gutted oem pump and basically just use it to carry the oil to the rest of the engine, much much cheaper then goin full drysump i can draw it in crayon if u didnt understand
