Kamin wrote:my car does this **** if i dont warm it up. one time it sat there and misfired for 20 minutes till everything burned off.
clean or replace your spark plugs, start it, LET IT WARM UP then go rip around the block and shut her down.
cold starts and stops are not the friend of your RB.
*sigh*Gotta be able to start it the first time...I think I need to pull the plugs out, clean them (even though their brand new), then get the air hose and blow out the cylinders...I think by this point I've probably flooded.
I pulled the plugs out, put them in the coils, grounded them and checked for spark...looks good as far as I can tell.Then after I put them back in, it acted like it was going to start, but didn't.
I tried some of that ether-based engine start stuff (both putting some in the intakes and then pulled the hose to the intake manifold and sprayed some directly into there). No difference at all.
And I was supposed to be putting it in a local open-house/car-show tomorrow.
