S13_RB25 wrote:Actually when you upgrade to N1 pump your supposed to screw the bolt back in or this will happen, coolant will leak out. The hole might be like that, oblong hole, but that 8mm bolt is supposed to go back in there.
We both installed the pumps with the 10mm bolt, but as ghost said, the oblong hole extends enough to the passenger's side of the block so that it does not create a seal with the coolant passage way.
After some researching, I found this to be a common problem. People either have it welded shut/re-drill the hole or use epoxy to fill the hole. Either way, it sucks! I wish I would have known about this before I put the engine back together! I guess Ghost and I will be making trips to our local welders to have the situation alleviated. Dammit, I was hoping to start this beast today.
