Darius wrote:That is normal for the mains.
Per the FSM page SD-9, the RB25/26 large end oil clearance is approximately 0.020-0.040 mm. Since I assume you used plastigauge to find the 0.003" value, you are golden. 0.003"=0.076mm. Divide that by two oil surfaces (0.076/2=0.038mm). That is on the bigger end of the range, but still within spec. Perfect for a higher hp application! Assemble away!
Darius,
I looked on pg SD-9 in the FSM for R34 and it talks about the manual trans gear specs but nothing about the engine. We used a feeler gauge to find the 0.003" value. I dont understand what you meant by dividing by two for the oil clearance. we measured the crank, and measured the block with caps assembled to get two numbers, subtracted them from one another to get the overall clearance. now we're trying to figure out how much of that clearance is for oil so we can figure out if the stock sized bearings will be sufficient. im not sure if i understand about the dividing by two thing. thanks for the help man! if possible, could you show me where in the manual those numbers are by posting a link to a pdf, or screen shot uploaded to like photobucket. i just want to see why my manual is different than yours. it is a R34 FSM right?
