RB26 MAF to MAP
Nesquick
Car: Rb26 Kouki Silvia
i had saved a link a LONG time ago on how to go about converting from MAF to MAP, but now the page is deleted :facepalm:
does anyone have a walkthru on how to wire the twin mafs together and wire it to the MAP sensor?
any help is appreciated. thanks NICO :)
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
voltage offsets r going to be off unless ur using a aem ems of pfc.
cant run map on a factory ecu or piggy backed ecu
Nesquick
I know.
I got a series 2 AEM with a gm 3 bar map sensor.
I just wanna know which wires I have to splice together
SullivanRacing06
use the aem 3.5 bar map not the gm 3 bar
the 5v to maf, maf ground and maf 1 signal wire going bk into the ems
Nesquick
i had the gm 3 bar lying around so im gunna be using it since money is tight right now.
since the RB26 has 2 MAFs, which one does the 5v go to? do the MAFs 5v have to be spliced together then into the MAP sensor? this is the only part im confused about otherwise I have everything else figured out
thanks for the help
SullivanRacing06
the front maf signal wire
Nesquick
thanks, thats what i needed. :)
one final question,
i forget which one is the front MAF signal wire :facepalm:
its been 2+ years since i took them off...
is it the connector with the curved neck, or the one without? (see pic)
thanks again
SullivanRacing06
i have my map sensor soldered in to the harness before it enters the ems.
FAST-DATSUN
AEM web site has the correct wiring for the MAP sensor.................
