SullivanRacing06 »
https://forums.nicoclub.com/sullivanracing06-u63212.html
Thu Mar 12, 2009 6:27 pm
im tryin to hook up a single q45 maf to my twin gtr maf set up, i used a voltage meter to figure out which wire is which on the r32 gtr maf clips, correct me if im wrong, so looking into the connector of the gtr clips from left to right, pin 1 12v, pin 2 ground, pins 3 ground, pin 4 sig, pin 5 not used.
is this correct? if so can i splice the 4 grounds together and run them into the q45 ground, hook up both the 12v to the q45 maf and the twin sigs to the single q45 sig output? would this be possible? im going to use this set up as a blow thru set up on my cold side of the i/c,
any help would be very helpful!!!!!!!!!!!!!
