fito »
https://forums.nicoclub.com/fito-u11706.html
Mon Apr 25, 2005 11:42 am
ok, here I go.
Rb26 and Rb25 rods are the same lenththe difference is in the pin location on the pistons, so Rb26 pistons will sit lower than the 25's. If you use the Rb26 crank, you'll conpensate that difference and bump the compression back up.
If you go rb26 pistons with either rods and rb25 crank, the pistons will not reach the top of the cylinder, lowering your compression. If you whant responce, this is not the way to go. Anyways, make notice that both rb25 and rb26 rods are SUPER strong, I did 587HP@ wheels with stock rb25 pistons and rods, I don't say it's safe but it's possible.
