RB26 Intake Manifold
Nesquick
Car: Rb26 Kouki Silvia
Hey guys,
I know this topic has been beaten with a stick over and over, but I cant find proper information on which manifold I should purchase.
I am currently using the stock one with a break in tune of ~300hp with a GT35. Ill be looking to push this turbo as much as I can for the time being.
In the future Ill be looking at a GT45 so ill need a manifold that will suit this as well.
Should I stick with the stock manifold and just get a EGT sensor for my #6 cylinder and tune around that temp? Or should I get a new manifold and EGT sensor?
Which Manifold should I be looking at?
Nismo, Greddy, RIPS, Others?
Thanks for the help guys
RRRRB
Car: 98 RB powered S14
i would convert to a single throttle body, no need for ITBS with a GT45... good tuning and watching plugs is key to a reliable setup
Nesquick
Signle TB had crossed my mind, not a bad idea either.
Would converting the stock manifold to work with a single TB be just fine? or should I buy an aftermarket one and then modify that for the single TB?
Im mostly concerned about the rear cylinder air flow.
