Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Tue Aug 09, 2011 5:11 pm
The swap is pretty much straight forward as any other RB swap and very similar to the RB25 overall.
You'll need a RWD transmission: most commonly used is the R33 RB25DET transmission.
You'll need to convert your wiring harness by using the RB26 main engine harness and your 240sx engine harness (or send it out to get converted)
Oil Pan options are to either cut the front diff and front axle prop shaft from the cast aluminum RB26 pan. You'll also need to remove the cross over pipe in the pan for the axle: weld up openings where axles use to be. You'll then need to grind down some of the ribs on the lower portion of the pan to clear the crossmember and steering rack (depending on what mount kit you are using). or Modify a RB25 oil pan to fit. There are write ups on both methods.
Conversion mount kit will be needed. Along with a custom downpipe or off the shelf downpipe for the conversion.
Modified radiator hoses, custom FMIC and piping, upgrade fuel pump, intake filters, upgrade radiator, electric fans... bla bla blah pretty much all the parts associated with doing any other swap into a 240sx.
Pretty much thats the bare essentials of doing a RB26 swap into a 240sx. There are obvious hurdles that you'll encounter but it just requires common sense when under the hood.
Hope that helps.
