wawazat8402 »
https://forums.nicoclub.com/wawazat8402-u20196.html
Thu Jun 05, 2008 5:39 am
Ive always wondered if an RB rail would max out sooner due to total system flow over an SR. If they max out at 600hp, hypothetically, say they are running 1000cc injectors. (This is just a guess, Ive never looked into what size injectors the 4 cyl guys run to hit those numbers.) If run at 90% IDC say theyre using 900cc's of fuel, again, completely guessed numbers because I dont care to calculate the actual flow at 85% IDC. Thats 3600cc's needed to flow the the rail just for consumption by the engine.
If we use 800s for the same 600whp at 90% IDC, which I will arbitrarily state as flowing 720cc into the engine. Thats 4320cc's total system flow through the rail for engine consumption. Does that mean our rail, if the same diameter and flow rate as an SR rail, will max out on smaller injectors than the SR guys can get by with or is my reasoning on this completely off base?
