strokerzedd »
https://forums.nicoclub.com/strokerzedd-u50073.html
Thu Nov 09, 2006 4:49 pm
I've read all 54 pages and still have questions before I start buying engines and parts. My '72 240z has a 3.1 litre that really can't be modified any more, but it's not enough, hence the RB26 install. I understand that the bottom end is strong but I still want to install aftermarket pistons and possibly rods, ARP bolts throughout. I'd like to clean up the head and upgrade the cams/valve springs, reatiners, guides etc. I'll install an aftermarket high pressure oil pump. What are the pros and cons re: injectors or throttle body? Is it best to retain the twin turbo configuration for lower end torque or use a large single higher rpm power, for the street? Which aftermarket turbos for each application? Which ECU is everyone happiest with? I hope that these questions aren't beneath this thread.
