StricNyne »
https://forums.nicoclub.com/stricnyne-u10935.html
Sat Mar 01, 2008 9:35 am
OK WOW, i need if possible a harness layout of the rb26, first off, rb25 has 2 coolant temp sensors that idk if rb26 has, , the coil plugs, are the same but i need a ignitor from a rb26 or modify one from a z32, basically outside of the coilpacks, cas, mafs, and injectors idk where the **** the rest of plugs go, and if i even have them like i also found out ineed a coolant temp sensor (both of them), oil pressure sensor
