t_blackout »
https://forums.nicoclub.com/t-blackout-u170688.html
Wed Oct 20, 2010 2:03 am
RB26DETT- I prefer R33 Motor
Rb25DET transmission-- sure
RB25DET Oil Pan????? in thailand we are custom made with rb 20det oil pan with directly bolt in with get rid of 4WD pan
RB26 full car wiring harness including ECU--- it came with the engine ,isn't it?
RB25 Tailshaft??? does this fit right on or need to be modified?--- I think it need some modification but it lenght have to be extened a little RB25DET transmission are alot longer ,if i remeber it right
In another option if you will not make power up to 400 HP then save the money and use rb20 transmission ,but You have to use copper clutch only.The carbon will make it blow up
Rb26 Fuel pump--- I recommend to use nismo pump which a lot cheap .The walbro 255 is good if you can hadle it,let say don't use 26 pump
Rb26 Radiator--- I know that you live in the difference area as the weather climate,But I suggest you to go for performance radiator if you want to pull out all HP form RB26DETT.it is mostly easy to heat up ,and quite be often around here in Thailand.
So, that is my suggestion .Hope you will find some more
