Rb26 exhaust manifold
PcCypher
Will an aftermarket rb26 single turbo exhaust manifold fit on the motor and in an S14 without major modifications? I know the stock twin turbos dont fit in there but I havent' been able to find any info on the single turbo manifolds.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
actually the stock twins will fit, you just need a different down pipe for them to clear. http://www.mckinneymotorsports.com/products
PcCypher
So its not the exhaust manifolds, its the downpipes that dont fit? So a single turbo exhaust manifold would work find? Someone please confirm this.
SeVa-S13
Car: '05 GTO 6spd
Depends on the manifold and turbo.
kaboomwoom
Car: 1995 240SX SE
would hks twin gt2835's work?
PcCypher
I'm looking to put on a gt4088r. So hopefully that will help.
JerryRigRB240
Car: 1990 240SX Coupe with RB20DET swap
It completely depends on how big the topmount manifold is. Unless it's bigger than most I've seen you should have no problem. You will need a custom downpipe
rb26tommy
Car: nissan 240sx s14 rb26dett
WELL I HAVE HKS GTRS ON MY RB26 BUT THEY ARE A DRIECT BOLT ON. ALL THE WATER/OIL AND GET A CUSTOME DOWNPIPE. BUT IF U ARE GOING WITH THE 2835 U WILL HAVE TO FAB NEW LINES WATER AND OIL AND DOWNPIPE.
ATpossible
Car: 1995 Nissan 240sx
im not completely sure the answer to your ?, but i did notice that the strut tower from one end to the other is actually shorter in length in a r32 than the s14. so if u r talking about major mods to the chassis or anything like that i would think it is fine. also the main frame side members (not sure about technical name) is the same length at that point in both.
hope that might help
full-race geoff
Car: R14
to use an RB single turbo manifold in an S14 chassis, particularly with a turbo like a 4088R, it is definately advised that you use a manifold which has the turbine flange moved *forwards*. otherwise the 40R compressor hosuing will not clear the s13/s14 shock tower
some pics:
Here is a pic of a guy who had the GReddy T88 kit, and swapped the turbo out for a GT4088R. the compressor outlet is running into the shock tower pretty badly
the solution to using that manifold seems to be to basically cut the compressor housing and weld on an angled extension (although it would be a better idea to do this more cleanly)
http://www.junsele.com/viewpic.asp?id=56871 (wont let me post the pic, only URL)
we just designed our manifold specifically for the S14 chassis. pictured here is our non-ac manifold. you can see how much farther forwards we've moved the turbo. its the only way to fit a 42R, and easily fits a 40R.
We are working on an AC compatible (and MAF compatible) 40R setup in the meantime
b-s14
any chance of a group buy on this manifold? ^^ i'm lookin to fit a borgwarner sc366 turbo on.
R33GTS-T
Car: 1991 s13 coupe
how much more stress is placed on the #1 and #2 runners having the turbo placed that far forward? (although while typing this i'm assuming that you braced the hell out of it)
- Daniel
