RB26 error code 13, coolant temperature sensor where is the location?
auy_tong2
Car: R33 GTR Nissan Skyline
i got a error code 13, where to locate the sensor?
Joe
near where the upper radiator hose connects to the engine. its the 2 wire sensor.
auy_tong2
so its on the radiator housing right? mine i think is on the lower side on the radiator... how to test the sensor if ok?
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
multi meter
auy_tong2
if i will test it in cold water, engine not running, what should be the readings on multimeter?
