ghost_22_47 »
https://forums.nicoclub.com/ghost-22-47-u149506.html
Thu Oct 06, 2011 5:43 pm
Ok so here is my deal.
Speed sensor works and reads in my cluster fine no issues using the Dakota Digital converter. However, Speed sensor was never wired to the ECU. This is what I am correcting.
Normally the Speed Sensor in an S13 is wired to a common ground and signal is sent to the Cluster Speedo then routed to the ECU.
Because I have an S13, RB26 and RB25 mesh I end up with much confusion.
The Big Question: Does the Speedo normally convert the signal from the Sensor to a signal the ECU can read when the signal travels through the cluster???
If NO, then I should be able to slice the origanal wire going to the converter and run a seperate wire to the ECU. BUT will the RB26 ECU be able to decode the RB25 Speed Sensor signal properly???
If YES, then can I take that converted signal from the Dakota Digital and wire it to the ECU and have it read correctly??? OR will I have to run a seperate wire from a seperate output on the Dakota Digital and adjust the signal until I see through Nistune that the Speed via the ECU is reading properly???
