Joe wrote:are you actually running a dome top piston?
yup. thats how CP makes their off the shelf 87mm RB26 piston.
here's what i've come up with...
Enter Bore/Stroke Designation Type
1 = Inches 2 = Millimeters 2Enter Cylinder Bore Size 87Enter Piston Stroke Length 73.7Enter Head Gasket Bore Diameter 88Enter Compressed Head Gasket Thickness 2.0Enter Combustion Chamber Volume In CCs 51.5Enter Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') 15.5Enter Piston Deck Clearance Negative If ABOVE Deck (Use '-') : -0.5715 Calculated Engine Compression Ratio 10.78 to 1. Total Displacement Volume 44.766 cc
Im pretty much screwed . i think its more the head than the block's fault.
The stock piston is dished...
The RB25 CP piston i think is dished based on google image search
Yet, the piston that was used by previous owner was a CP RB25 piston stock bore and it was domed... you can see where the valves were hitting when used with RB26 crank and RB26 rods.
and my piston now... RB26 87mm 8.5:1 off the shelf piston, domed.
Im going to cry. help.
Modified by sickness14 at 4:31 PM 1/29/2010
original owner of car's original build...
"well, i thought long and hard about it over the last few days and decided to get a set of cp pistons at 9.5:1, pretty much an identical (forged) replacement.
so i called up CP Pistons for a custom set because they don't offer it off the shelf. Since they don't deal with the public they referred me to JGY Customs because that's their closest vendor to me. so i'll be sending #1 and #6 piston to JGY tomorrow, then they send the specs to CP and CP sends me my pistons."
crap, so i guess he did have custom pistons ordered to use the rb26 pistons in an rb25.
he also said:
"i went with the rb26 crank with the good oil drive and the rb25 pistons wouldn't work because of the wrist pin."
which explains that i guess an rb26 piston has to be used with the rb26 crank.
Modified by sickness14 at 4:54 PM 1/29/2010
Modified by sickness14 at 7:52 AM 2/1/2010
