RB26 cover screws measurment help!!!
ghost_22_47
Car: 1993 Nissan 240sx Covertible with RB26dett
2004 Audi A4 1.8T Quattro
Ok I have calipers and have measured this with them just dont knowhow to convert to metric or what to look for.
Over all goal is to replace carbon steel black oxided screws with stainlesssteel screws.
I'd appreciate it if someone could help me do this, I am going to try andget them from here http://www.mcmaster.com/# you can get almostanything from this place.
Over all length: 1.180inOver all thread length: .704in give or take a littleScrew thickness thread to thread: .191inMeasurement between each thread: .050in give or take a littleMeasurement between every 5 threads: .140in give or take a little
If anyone has different measurments please let me know if I screwd up.Like I said any help is appreciated.Thanks everyone
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Not sure what size you need, but that isn't the way I measure screws and bolts.
Just take the bolts you have to a hardware store, and I guarantee they will have a thread-testing board thingy you can use.
Unless you know exactly what size metric thread you need (e.g., m6, m8, m10, m12, etc.) just do that.
Furthermore, you should be able to get the bolts you need from most hardware stores, and most grade 8 bolts from NAPA.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Get some allen-head cap screws with a washer instead of trying to find a similar OEM replacement. I provide these with the valve cover isolators that I make and they look much cleaner. I am going off of memory but I'm pretty sure they are M6x1.0x30mm long. I'd double check the thread pitch on that.
mattblancarte
Darius wrote:Get some allen-head cap screws with a washer instead of trying to find a similar OEM replacement.
^^ This is what I did, too.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
For the timing cover, correct?(couldn't be for the rocker covers, too long)
Darius
I'm almost 100% sure the 30mm is correct. Measure up the set I sent you
