Coolwhip wrote:damn man, you haven't solved this issue yet?
We need to see what balancer you are using and what power steering pump as well.
Reason being is that the R32 RB26 offsets the powersteering pump belt by a few mm out than the RB25 and also uses a 4 rib belt. The R33/34 also misaligns the powersteering belt as well differing from the R32 RB26 setup.
Since you have a swapped motor you need to figure out what components were used.
One of the reasons why the Ross Tuffbond MetalJackets (RB26 app) had underdrive the powersteering pulley was to prevent the tossing of belts. I spoke to Ross about this as the stock and previous model balancers were tossing p/s belts on track cars on various power levels (majority being higher powered/revving motors).
If you are eating a rib on the belt it's more than likely misaligned as in a mix and match of components between pump and balancer.
Hmmmm... I'll need to call the shop that did the motor swap (G-Dimension) to confirm, but this is beginning to make sense. The motor is a frankenstein of r32, r33, and r34 parts. Crank (and balancer, I assume) is r33, which makes me think that the balancer is, as well. The pump, I have no clue. I'll look into this more in depth, and take some pics for you guys.
I'm a total n00b when it comes to wrenching, as in I know track maintenance and basic basic stuff.
Luckily, my businesses partner's dad is in town and he is a very experienced fab/mechanic (even though he is an airline pilot for Alaska Airlines). He's going to help me a align it best we can, but after hearing the above wisdom... I have a feeling that it may not be the complete issue.
SamuraiSam wrote:Dude. Pacific Raceways is a beast. I love it. Are you using all stock bracketry and pullies? Sometimes the RB25's and RB26's get swapped and don't work properly. Sometimes the wrong bracket and right pump. Sometimes the right bracket and wrong pump. Previous poster mentioned a big issue, which is the difference between the 'Early' and 'Late' crankshaft styles which move the main damper a little bit. I like to use the ATI damper, and haven't had any problems with belt misalignment yet. The nice part about the ATI is the front powersteering drive is removable/space-able- a swapper's golden ticket.
If you don't get the issue fixed before moving, please swing by our shop:
http://www.upgarageusa.com. We won't charge you anything to take a quick look.
It seriously is! I don't want to fly around turn 1 at 150mph and lose PS! That could spell doom for me and the car at that speed.
Some guy in TT group 2 smacked into the oval at PIR this past weekend, and probably would have died had he not been wearing his HANS device.
Greddy pulley, stock damper I believe. Pics may confirm this one way or the other.
I'll swing by your guy's shop just because you have that ridiculous yellow S chassis with the 26. So beautiful!
