RB26 cams-RB20, stock injectores on rb20...
90240sxca18
Car: 1990 nissan 240sx ca18det
question number 1. will rb26dett OEM cams fit directly into a RB20, and if so what difference will there be?
2. what is the max whp estimated out of stock rb20det injectors (270cc). thanks.
Carl H
it has been found that only the r32 rb26 cams work somewhat well in the rb20...and you'll need cam gears to reset the cams to their proper locations...not worth it when a set of drop in cams can be had for about the same price.
i wouldnt push more than 230whp thru stock rb20 injectors...they simply cannot provide the fuel needed for good power.
