I just installed some rb26 cams into my rb20, swap was pretty interesting.. I learned a lot, quite fun actually.
I cant seem to get solid specs on both of these cams, everyone has a different opinion on what is supposed to be "facts"
Here is what I came up with:
RB20 intake - 240 degree duration 7.8mm liftRB20 exhaust - 232 degree duration 7.3mm lift
RB26 intake - 248 degree duration 8.6mm liftRB26 exhaust - 240 or 248 degree duration 8.6mm lift
I marked the piss out of the timing belt to make damn sure everything went back together properly.. And it did.. So I think.
When it first fired up (first try) the idle was so bad! I was so exited that my car had such a horribly awesome cam idle... Reminds me of my friends c5 LS1!
Now I'm starting to think the idle is just plain unhealthy, and although it shouldnt be as smooth as stock, it should idle better than this...a lot better. It wants to die coming to a stop, and 90% of the time wants to die instead of idle anyway. I lost a lot of low end, which was expected.. But now it seems as though the car takes longer to get to redline, and doesnt feel any faster top end, maybe even slower. Now I did have some correction with my SAFC before (8%-12% less fuel across the board), which I reset to stock. The timing feels retarded, but I cant get it timed properly with my bad idle... I *think* its timed properly, but I just cant be sure...
I replaced my O2 sensor and spark plugs while the car was apart, with a sensor from an 84 200sx turbo. I believe I found that cross reference on this board. The sensor end is different from the sensor I pulled out of my car, so I'll try swapping back to my old sensor... its a long shot, but maybe thats causing a poor idle.
Anyone have any suggestions, or done this cam upgrade themselves?
Video:
http://www.youtube.com/watch?v=VQW1AAPi4tc
Thanks!-Max
