rb26 booster vaccum tube
ATpossible
Car: 1995 Nissan 240sx
i need help knowing where the booster vacuum tube goes and connects to.
not the air chamber side but where the hose connects to the end of the tube.
on my tube one line is going through the 5th and 6th runner between the throttle and the other is just outside the plenum next to the 6th runner.
is that right? i cant tell from the fsm which is below with a red circle of the piece in question.
Thanks for your help in advance
BHFR-GTR
Car: 1993 s13
if you are asking what the connect to , one side goes to the brake booster and the other is just capped off, cause it is not used in the 240 swap
