Actually the RB26 uses 444cc low impedance injectors....just an fyiC33LaurelRacer wrote:Not sure on how much boost you can run, but the injectors should be top feed 440cc high impedance.
How much would it cost/where would you go to get the stock turbos rebuilt and the wheels upgraded? I have two turbos sitting here from my motor, that I have been thinking about rebuilding and selling.underground wrote:The first mod I would do on a GTR block is replace your stock turbos with N1 Turbo's or have the wheels on the stock units upgraded.
Ok, then it's the RB20 that uses high impedance injectors then. I always get that backwards. Thanks for clearing that up.002-M-P wrote:
Today I was at this shop dropping off a pair of Nismo R32 N1's for rebuilding. http://www.turbo-power.com/index.htmThey are charging me $375 each for the rebuild. They do have all the proper equipment. Next week I pick them up. Located in Northern California though.002-M-P wrote:
