evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Jul 10, 2008 8:44 am
I'm a bit confused, you are running the rb20's trans now and want an rb25 trans? but can't find one so youwant to run an RB26 bellhousing with a "king daddy" trans?
the RB25 trans is the same as the Z32TT trans save for the front case (it's not really a "bellshousing" on these trannies, they use a front case and a rear case with a thick plate in the middle thatt he shafts run through), the RB26 trans I believe is built the same way witht he exception that the rear case has the "differential" to send a driveshaft out frotn for the frotn wheels so I "think" taht the frotn case form the RB26 could be sued in a conversion, the RB20 uses essentially the same trans as the 240SX, ca's, SR's and Z31 n/a's as well as trucks and a few other cars, built much the same way but not at all interchangable witht he larger RB trannies, and what si a "king daddy" gearboy?
this help at all? am I understang you correctly?
