rb26 apexi power fc d-jetro on rb25?
fast_s14
Car: 94 300zx
Has anyone on here had first hand experience on what needs to be modified to make the rb26 d-jetro work on a rb25? There used to be a link on skylinesaustralia but the link is dead.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
carlos is doing this at the moment. Bet he'll chime in.
Cjmartz2k
Car: Hunting for a '89 GTR now
I think just a little swapping of ECU wires is about it. My shop guy has done it before. I'll ask him when I get back to Oki. You loose VCT unless you rig something up, but I'm sure you already know that.
StricNyne
http://paulr33.skylinesaustral...q.htm
but its temp down, it can be done, i am wiring in this msd rpm activated switch for my vct also, i will post up details on my statues update i got planned
Vandrel
Car: R33
i would like to get the details on how to do this as well
fast_s14
Car: 94 300zx
StricNyne wrote:http://paulr33.skylinesaustral...q.htm
Yep thats the link i was talking about. I have been thinking about this for awhile and the rpm activated switch is about the best way about keeping the vct in my opinion.
StricNyne
hmm i think i have the links saved on my desktop comp, as far as the msd rpm switch, i got this one, since the vct solenoid just gets 12v within a certin rpm range u just program the range in the msd switch, and wallah u done, and the good part is thats you can control it 10x easier, so u probally can adjust your engagement to be more compatible with your turbo
http://www.cimotorsports.net/m....html
as far as power fc adjustments, you have to wire in the o2 and maf sensors in parallel, what the power fc for a rb26 does is take the 2 signals and divide it in half when it makes it calculations, also the rb26 has a air intake temp sensor for timing retardation, its the same sensor as the coolant temp sensos, i just tapped my intake piping and put it there
also i have a rb26 harness also thats why i did coolant temp sensor, i read that u dont have to use it
sil_eightyRPS13
Car: 1989 RB27 cefiro
yes i run this setup...it has to do with the maf ground and the new map ground have to switched... and vtc is not used as i have deleted it...
for fruther information call or look up UNNATURALINC.com in portland oregon as they have the secret, and they are also a power FC power excel qualified dealer..
-good luck
-Mark
