RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Mon Oct 25, 2010 7:02 am
Doesn't mean they are the same resistance. You can't use a maxima sensor on a 240sx even if the connector is the same the resistance curve is not.
Maybe you got lucky, but the air temp sensor changes your timing and fuel curves. Id want to make 100% sure you have the right one. It might just think it runs hot, and pull timing, or it might add too much timing. Not something I'd want to risk.
~Alex
