RB26 88mm Pistons
Capt. Raptor
Does anyone know where I can get 88mm pistons for the RB26 that will provide a 8.5:1 compression ratio? I haven't had much luck looking for them with search engines such as google.
StricNyne
wiseco makes custom pistons additional 50 bucks i believe
Chaos the Xile
Car: 1974 Datsun 260Z
BC(Brian Crower) makes them and i believe that JE does too. All you have to do is decide which companies pistons you want to use, call them up and see if taht supply them.
TomeiHKSBrian CrowerWiescoCPJEAries
Just to name a few
nismo8117
Car: 93 SilLine
why do you need to go 88mm?
legit240sx
Car: 91 240sx rb20
look up Nick Arias at atomic speedware way cool guy and got me my pistons $100 bucks cheeper then any one else. He has major hook ups with alot of piston co.
StricNyne
i think the 88mm headgaskets are a pita to get and thats like the limit of a rb block
Capt. Raptor
Which of these companies tends to be the cheapest?
rbs14kouki
Car: rb27det s14 / sr20det s14
87.0 is preaty much the safe limit for the cylinder wall to have a high HP rb26
i change my old block because of that !!!!
if it's a dayli , go for it but dont push it hard !!!
Capt. Raptor
I know this is somewhat risky but I've heard of it being done successfully. I know that the Brian Crower stroker kit can be used with a 88mm bore and it has worked out for those who have used it. So I think its worth a day, and this car will still somewhat be my DD and just a fun street car so it will never be constantly under max boost or pushed to max revs so I think it will be okay.
Joe
Capt. Raptor wrote:I know this is somewhat risky but I've heard of it being done successfully. I know that the Brian Crower stroker kit can be used with a 88mm bore and it has worked out for those who have used it. So I think its worth a day, and this car will still somewhat be my DD and just a fun street car so it will never be constantly under max boost or pushed to max revs so I think it will be okay.
Capt. Raptor wrote:Which of these companies tends to be the cheapest?
stop right there.
cheap, reliable, fast. choose 2. you will never have the third.
p.s. 88mm is pointless and retarded. you cant honestly be doing this for a displacement upgrade, right?
nismo8117
Car: 93 SilLine
Joe wrote:
stop right there.
that is exactly why i asked he wanted to go 88mm its kinda pointless but hey whatever its his money...
