RB26 5V system.
Nesquick
Car: Rb26 Kouki Silvia
so i was playing around with my ign timing on my S2 AEM EMS and almost had the timing dialed in to start running, then all of a sudden all the sensors on the 5v system showed the wrong figures.
my MAP sensor, throttle position, coolant temp, air temp sensors, are all showing really low volts :confused:
i got no spark, and no inj.
i unplugged all the messed up sensors and checked the voltages, and none of them had anywhere close to 5v (battery is charged btw).
here is a pic of the voltages on the EMS
is there any way of figuring out if i shorted something out or shorted out ALL the sensors, or the EMS itself?
i tested pin # 48 (AEM tech line told me to do this) off the ECU plug and it read 0.00v :confused:
what is my next move?
*EDIT* all fuses are good as well
boostedh23a1
Car: Datsun 240Z
Datsun 280Z
I had the same problem with my S2 ems. i check it with the oem ecu and all was good, had to send the ems back to aem... now it works but i have no warranty now...
Nesquick
That's not what I wanted to hear :( lol
If I got a new EMS, wouldn't it just short out as well?
LeD ippen
Car: 1993 Nissan 240sx SE
make sure there is no short in wireharness before you get new ecu. happened to a maxima and intrepid i had at the shop did same thing.
tps coolant temp and 4 others went to full output 100% or 5v .
Nesquick
Just confirmed that it's the EMS. I checked the voltage at my MAP sensor with the AEM, read .13v. Plugged in my power fc, 5.1v...
Damn...
boostedh23a1
Car: Datsun 240Z
Datsun 280Z
tell them to put a new warranty sticker on it. :)
