Hey, ive got a check engine light on my dash, i looked at the power FC sensors and its showing "THRM" sensor highlighted. after searching on skylines australia and skylines down under forums, ive convinced myself that it is the traction control system that is not hooked up. there is a fix that can be done using a 510k ohm resistor tapped from pin 51 on ecu to ground, providing the right 3.5v to turn off the CEL. the only question is... when i look at my ECU pinout for my 98 R34 GTT Neo motor, it doesnt have a matching ECU pin that the Stagea has (the car that skylines australia is using for the example). does anyone have any more knowledge of this? im tired of the light being on, but i want to have it functional for the knock warning of the power FC. thanks!!!
PS: check out my build thread in the mean time
zer...age=1
Modified by sickness14 at 3:35 PM 2/4/2009
