bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Tue Jan 04, 2005 9:05 am
Personally, if I was in your situation, I would try to get a RB26DETT front clip. I believe that most, if not all, RB30s are single cams from the factory, but people have swapped RB26 heads onto RB30 blocks to make them dual cam. I have seen RB26DETT clips on some websites in the past, but I would expect to pay about $8,000 to $10,000 or more just for the clip. Then if you get the RB26, you have to buy an RB25 transmission because the AWD transmission on the RB26 won't work on a 240. After that, probably another $2,000 at least in parts and fabrication to make the swap work. You might run into a little trouble getting both turbos to fit under the hood also. But if you get it done you will have an awesome car!
