rb25dett help!!!
nisilvia
Car: 1998 Nissan 240sx rb25det, 2007 BMW 335i
hey guys i did timing belt,all the accessory belts, tensioners, and a water pump change a feww months ago. When I put the CAS on the camshaft i screwed the bolts down too tight and it grinded on the front of the cam shaft and the back of the CAS. It grinded pretty bad and now I bought a new CAS and installed the and didnt tighten it too tight but I still here a grinding noise from somewhere. I cant find out where its grinding from. Any one have ideas of what I got myself into? Should I take the valve cover off and check for somethings before I have it towed to a shop? sorry for making it so long just wanted you to have an idea of whats going on. thanks alot.
nisilvia
If anyone is in the worcester mass area and could help me out I would appreciate it.
