breaker_bo1 wrote:can anyone help me with my 240sx swap rb25det; when I try to crank it, all I hear is some relays clicking and a buzzing sound, can you help me with it, and on the stock 240sx coil (number 1 on the picture 1, which is the stock 240sx coil) I dont know were it goes, and number 2 on picture number 1 is a plug that I dont know where it goes, and on picture number 2, I dont know where the plug goes, and the other pictures are just pictures of my motor in my 92 240sx.
Picture 1: Unless you are using the stock ka distributor, you need to lose this baby.Picture 2: This appears to be the plug that feeds power to the starter, remeber when I told you to make sure its all 100% correct before sending it back & to ensure your battery is fully charged? You didnt share with me the part about the relays clicking, you could have a low battery!!!engine1: I hope this pic is just to show off, cause the wires draped across the eshaust will melt real quick! That kink in the radiator hose dont look too good either.Intake side: fuel pump fuse should be a 10 amp, not 15Top of motor : make sure there is no vacuum lines left open, it will cause starting/idle problems if there is a vacuum leak!!! Why is there oil on top of the coil cover?and also does anybody know what starter interchanges with an rb25det or where I can get one
Just send yours in for rebuild
What color are the wires in that plug?breaker_bo1 wrote:Ive already have my alternater pluged, since the other 2 plugs that goes to the stock 240sx coil on pic # 1 goes to nothing anymore, the only plug left is the one on pic #2
yes.David_NISMO wrote:if the motor is in the condition it is in now, no intake piping, why does it matter if the maf is even plugged in? I can start my motor without the MAFs plugged in. Some sort of safety mode, so you can limp your car home. But..., if his MAF is plugged in, but NO air is moving through it, would it still start?
