titangts wrote:or could it be a boost leak...maybe i blew something ( like something in the cooler pipes) and the air releases and but the ecu still throwing the fuel needed but it doesnt get burned so it fouls the plugs out and causes it to stall???????
By the way you describe it happening after doing a slide makes me think it is a boost leak at a coupler that only lets loose above 6 psi. Try checking all of the clamps and if that doesn't work, make a boost tester (search the RB forum for details) and check for leaks elsewhere.
Can you free-rev the engine above 3500 rpm in neutral or does the PFC limit it below redline?
