I found on turbododge.com a guy said that the HX30 flows around 46lbs a min, and on another forum (I forget which exactly) that its good for about 300-350wHP w/o much of a problem.
So it looks like a GT25R that is capable of more power and better spool and higher pressure ratios. Now I just have to find one.
http://www.holset.co.uk/mainsi...0.php
On garrets actual site, they list the HX40 has flowing .53kg/s and being good for 350hp. The HX35 has .46kg/s and 280hp, and the HX30 .35kg/s and 240hp.
And following the general rule of almost double the HP on a gas engine, and you have approx ~600HP,~475HP,~400HP capable turbos.
Hmm I'll have to order some deutchwerks injectors soon and get nistune from a local place. And then get a hx30 and max it out on my buddys dyno.
~Alex
