RB25DET Wiring issue
Rbvert
I bought the Wiring video from Drifting.com to wire the rb harness to S13 and hit a little wall with inserting the power interface. He says that i need to connect 3 wires to the Black with red stripe wire that came from the RB interface. My problem is that i dont have a Black with a red stripe wire on my interface. I look at many schematics online and my harness seems to be different, some of the colors and pins dont match up. Wondering if anyone out there could help. Here are some pic of the RB interface.
Thanks in advance for help
Modified by Rbvert at 8:53 PM 10/22/2009
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
you'll find your wire here.
http://www.gweeds.net/carpage2/rb25diagram.jpg
it shows the proper color codes and pin numbers just trace it
Rbvert
From my understanding everywhere there is a letter and number (like AF36 B/R wire) should be wires correct? But on my harness it not there, some are there but not all. I looked at is schematic many times and traced them and came up with nothing.
Rbvert
Bump!
foulplay
Car: 1992 S13 Fastback
af36 should be the same as pin 45 on the ecu plug.
