Darius wrote:The engine should idle normally with stock ECU, MAF, and injectors. FPR isn't necessary but you may need to verify that the stock FPR is able to maintain fuel pressure under boost.
Have you checked for boost leaks with a pressure tester?
Have you verified the ignition timing with a timing light?
What condition are the coil packs in?
Do you have a wideband O2 sensor?
Is the IACV screw turned all the way to the right, less 1/2 turn CCW?
Did you do the idle relearn procedure each time you changed MAF sensors in the PFC?
Did you change the MAF sensor setting each time you changed MAF sensors in the PFC?
i dont have a pessure tester but my boost and vac stay steady according to my gauge
no but i will if i can find a extra spark plug wire layin around i dont have the right timing light to use the white ign check wire.. i can check it on my pfc do u know what its supposed to read??
no wideband
i didnt mess with the ivac i simply took off the stock mani, cleaned, and installed on the freddy
yes i did the relearn
yes i changed the maf setting
