Is that what you are basing your argument on or do you actually know anything about the pump and what it does?jrhdohc wrote:yes it is an upgrade. R34 Nur has N-1. it is a factory street car.
Unless you enjoy idling your car in traffic on a 90* day at 90% humidity with the a/c on and you have a 4" thick front mount blocking some airflow to the radiator. Ask me how I know.jrhdohc wrote:i'm not trying to argue. i'm just saying it is. you don't trust me so i'm telling you another source, Nissan.flow at idle is not as important as flow at speed...
says who?jrhdohc wrote:i'm not trying to argue. i'm just saying it is. you don't trust me so i'm telling you another source, Nissan.flow at idle is not as important as flow at speed...
look i don't need to justify myself to you. it is what it is. better. you are too closed minded. it has led you down a path to ignorance.Joe wrote:
says who?
you are wearing my patience thin.
since 99.5% of the cars on this board will NEVER see a track long enough to warrant use of that pump yes, flow below 3000rpm is FAR more important than flow at 6000+rpm
you are one of those people that thinks that just because its on a racecar that means its better for everyone right?
