OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Sun Apr 22, 2012 12:53 pm
Actually it goes from vss to the speedo. The speedo is 4 wires power, ground signal in, and the converted signal out, the ECU has a comparator circuit which uses engine load and speed and reports back to the Hicas ECU where that unit controls the electric steering rack based on the values it sees including the front steering pressure and angle sensor.
The issue is that I do not have continuity from the VSS to the speedo. Which happens to pass through about 4 body connectors which all visually look good (some require removing the dash to check). Wheel well harness much like 240sx looks good too. So my plan is to rewire VSS to the cluster, and cluster to the ECU. But since I have noting to compare to I was looking to see who knew which was was which at the VSS factory, then I have to determine which of the two terminals is in and out on the Speedo.
