rb25det vibration when accelerating...any thoughts?
johnrb25s14
I just got my swap not to long ago and a problem had basically plagued me from the beginning. At the beginning the vibration came on and off at times. Over time it got worse and worse. At one time i thought it was just maybe using an octane booster because the problem seemed to appear whenever i filled up my tank. I changed the spark plugs since they were definately burnt out and that didn't fix it.
Can the problem be the fuel injectors?? I never had this problem with my old ka motor and with this rb25 skyline motor it just got complicated. With the vibration it seems to lower down the idle. I checked the vacuum hoses and everything seems to be connected just fine.
Anyone have any thoughts??
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
is the vibration throughout the entire car or through the steeringwheel or what? where do you feel it?
johnrb25s14
the vibration is felt throughout the car. I definately know its not the steering or suspension. A subtle clicking noise seems to be comming from the side of the intake manifold. When i accelerate i feel the shaking from in front of me (engine).
spark plugs didn't fix that problem...
WorkinDriver
Car: 240's
Check the motor mounts.
johnrb25s14
just fixed the problem. Seemed to be one of the plugs from the igniter chip that was covered with a white corosion, but is working perfectly fine after cleaning all the plugs in the engine bay. I also reseted the ecu for about 12 hours, which also seemed to work with my small problem of running the a/c and stalling. Im guessin the idle adjusted itself.
