DustinZ wrote:Neo Turbo wouldnt net you any more power at all. It can only reliably be boosted to 10psi before you grenade it. The turbo has a polymer compressor wheel and a ceramic turbine. The polymer compressor wheel is actually more fragile than the turbine. They spool super fast but dont boost them too much!
DustinZ
This is true. Man, those guys on skylinesaustralia spread so much s*** all over the internet it's not even funny. Half the stuff they swear is "fact" is just regurgitated from what they saw somebody else said.
The older compressor wheels were metal. The newer (neo) ones were a polymer (plastic) and the neo compressor wheels are more delicate than the older ones, but they spool a little faster since they are lighter. All of this is a mute point since they all have the ceramic blades glued to the shaft for the exhaust side, and that is ALWAYS what comes apart. They are all weak d!ck little turbos also, so as it was said earlier, who cares.
