Trini.Madman »
https://forums.nicoclub.com/trini-madman-u212907.html
Tue Aug 27, 2013 7:29 am
Ok well to begin with, I wont be using the OEM exhaust manifold, I intend to use a aftermarket extractor type manifold. I believe this will help with Lower end torque.
Also, Piping and modifications isn't a problem, so external waste gate vs internal, If it doesn't affect spool response or makes any positive/negative impact in anyway, it wont matter to me.
I don't have any sort of "power goals" what I want is more response from my NON-Turbo engine which is supposed to be higher compression. Now I know I can only go so far with the stock turbo.
I am looking for a turbo that will perfectly suit my responsive needs for my application.
I will be
-upgrading intake manifold (slightly bigger injectors)
-upgrading exhaust manifold
-Going with a small fmic
-probably 2inch piping maybe 2.5 if its necessary but I think 2inch will help with response
-I will be installing Oil Squirters but I do not want to upgrade internals as its very expensive where I live.
(its cheaper to install a full turbo kit than upgrade pistons and rods)
-will be tuning with a AEM-F/IC6
-Will install a FPR
-Will Probably Upgrade fuel pump if its necessary.
For a "workable figure" lets say I want 300hp at the wheels? so off idle, with my automatic transmission, I can loose the traction with ease if I WOT.
Was wondering if it makes sense Installing a N1 Oil pump and Oil cooler while im at it?
But that's what im looking for, with the number 1 thing being RESPONSIVE TURBO! I need to be spooled as I press the throttle at any RPM, or it wont make any sense to me to turbo the engine.
