crazyandevil05 »
https://forums.nicoclub.com/crazyandevil05-u69665.html
Fri Sep 04, 2009 6:09 am
no, you really havent searched if you couldnt find that. basically your stock computer will only say "injectors, stay open for X miliseconds" based on how much fuel should be put into the engine since it knows how big the stock injectors are. but if you double the injector size, the engine will still only say "injectors stay open X miliseconds" because it thinks the injectors are still stock, so you'd be dumping twice the fuel into the cylinder. now the computer can adjust up and down, based on the o2 sensor, but not enough to fit in bigger injectors. if you're going the bigger turbo and injector route, definatly do not skimp out on tuning. and with a bigger turbo, injectors would have to put in if you're planning on going more than ~ 300 hp (and actually, i would suggest even then, just because theres no point in upgrading your turbo if you're not doing that, and 300 hp is still pushing it on stock turbo and injectors). so, you should just keep it stock until you can get a GOOD tune. no point in dumping money into a huge turbo and everything, just to have you're tune ruin your engine. would you rather have 350 hp that runs, or a 500 hp monster that is going melt down?so, for tuning i personally just use a SAFC II, which is fine for me, being stock but for a boost controler and small fmic. i only have it to adjust for my MAF. but if you search, you can find loads of info, on everything from megasquirt to nistune (i know, because i have searched yahoo and the forums and found boat loads on this). sorry to rant on, but i've been wicked bored!
