Should I take this to mean that the turbo isn't a very good design? What is the A/R of the exhaust?Kamin wrote: the S2 wheels run a steel wheel that is safer higher but is still well outside of the efficencey range of the turbo.
i wouldnt count on it all are ball bearing, some are not BB--regardless, these oem turbos are purposely designed to have low power output--overworking it only shorten its life.Shocker wrote:yea they are ball bearing, water/oil cooled turbo. if your looking for just 225 hp, it should suit your needs just fine.
