240sxed »
https://forums.nicoclub.com/240sxed-u28683.html
Tue May 31, 2005 4:28 pm
Today I bled my newly swapped rb25 swap. After bleeding it for a while, bleeding from the dampner box and from the slave itself, we couldn't get the pedal to firm up as much as we would've liked, nor could we get it to return fully. When I tried to shift into first, it was hard to put in gear, but no grinding, same with reverse and second gear. When im fully depressed on the clutch, the car moves forward if its in first gear.
Im wondering, could it be the master cylinder ? I don't think its the slave cylinder b/c i bought a new one from mckinney to prevent this kind of thing from happening? Im going to try the one that came on the transmission tommorow.
After bleeding the thing a while, only 1/4-1/3 of a regular sized water bottle, the 1 dollar bottles. Typically when i bleed the clutch i coulda sworn almost half the bottle gets filled from bleeding? or maybe thats only the breaks? I don't see any leaks coming from any of the lines... could the masterclyinder still be bad?
Ive tried to search on it, but it seems like some other people have had similar issues, but im not quite sure if theres were only related to the trannies or to the throwout bearing used.
I've done many clutch jobs, know how to put on the TOB and grease the inside where it goes on the imput shaft...
specs:
z32 n/a ACT 6 puck heavy duty pressure platez31 thow out bearingpilot bearing that came with the z32 n/a kit.
valvoline 75-90, figured i'd flush it after about 1000 miles along with the oil, and put in some redline.
